Language Settings for a Modules
I want to define the japanese name for the modules i.e. "Create "  and "All" module ,where we can configure these settings.
Hello @Community Alums
go to sys_translated.LIST from filter navigator.
from the list search for All in the value for language Ja
as mentioned, there must be value in the system already when language Plugin installed.
Help others to find a correct solution by marking the appropriate response as correct answer and helpful!!
Kind Regards,
Ravi Chandra.
If the value field empty,  is this works fine ?
no Yashin.
that is mandatory.
to give you more context, value is the base English language value you are translating.
label field contains respective language translation.
Kind Regards,
Ravi Chandra.
Okay understand, when i am trying to enter with the vlue getting error (PFA) and i have checked for the duplicate entries but there is no duplicate values. Please assist me on this.
Kind Regards,
Ravi Chandra.
