length of an array
Prasanthi1
Giga Contributor
while executing the below, I am not getting the length of list.
inc.addActiveQuery();
inc.query();
inc.next();
var list = inc.getElements()
gs.print(list.length);
showing output: undefined
why? please explain..
Seems the docs has incorrect information.
I tried the script from docs to get the length but it failed
We need to convert that to Array and then get the length
Maik Skoddow
Hi @Prasanthi ,
as you can see on page https://developer.servicenow.com/dev.do#!/reference/api/quebec/server_legacy/c_GlideRecordAPI there is no official method .getElements() for class GlideRecord.
What did you expect to get?
Kind regards
Maik
If my answer replied your question please mark appropriate response as correct so that the question will appear as resolved for other users who may have a similar question in the future.
Prasad Dhumal
You are using .next method, there is no need to use this Method.
next() method returns the next element and also moves to the next element.
Try below code into Background Script, you will get Output.
inc.query();
gs.info(inc.getRowCount());
Please mark my answer as correct and close the thread so that others can also benefit.
Prasad Dhumal
Prasanthi1
Giga Contributor
Here my question is, while printing length of array, I am not getting the length.
Is there any error in my code... please explain my code only.
Thank you
@Prasanthi
Did you get a chance to check my comments above
getElements() would give you java object so convert that to Array and then use length
Script: This will give the length
inc.query();
inc.next();
var list = new global.ArrayUtil().convertArray(inc.getElements());
gs.info(list.length);
Actually getElements() methods returns array of objects, then why we agiain convert this to array?
