List Collector dynamic reference qualifier for catalog item
Michael M1
Giga Expert
I have a list collector variable on the sys_user table in a catalog item and I want to update the filter on the collector based on a selection of a drop down on the catalog item. I can do this as a catalog client script but I am having trouble setting the encoded query.
I want to encode 2 things
- show only users whose manager is the current user (i.e. requestor).
- The requestor chooses expires in 30, 60, or 90 days from a drop down list. I need to show users that have u_expires date field less than 30/60/90 days from now.
Jim Coyne
OK, actually, we should be able to accomplish this without a Client Script:
1. set the Reference qualifier for the List Collector to the following:
javascript:"active=true^u_user_type=Consultant^manager=" + gs.getUserID() + "^u_expiresRELATIVELT@dayofweek@ahead@" + current.variables.number_of_days;
2. set the "Variable attributes" field for the List Collector to the following:
ref_qual_elements=number_of_days
The "ref_qual_elements" attribute will send back to the server the current values for those variables so they can be used in the reference qualifier.
Replace "number_of_days" in both the Reference qualifier and the "Variable attributes" field with whatever your variable name is.
I tried it in my dev instance with "Company" and "Users" variables and the Users list collector changes based on the selected company.  In both the regular and portal UIs.
11 REPLIES 11
Jim -
I tried this article already and for whatever reason it does not change my filter. I was wondering if you have a pre-defined ref qualifier on the variable it wont work. I may try to remove it and see what happens. Or maybe as the qualifier I can just call the catalog client script?
Here is what I had - I just started with a basic filter of show me everyone - but it didnt work.
g_form.setValue('choose_contractors_to_extend_or_disable', ''); //this will clear out the list collector
var collectorName = 'choose_contractors_to_extend_or_disable';
var filterString = 'active=true'; //I will change this
setCollectorFilter();
function setCollectorFilter(){
//Reset the filter query
var myListCollector = g_list.get(collectorName);
myListCollector.reset();
myListCollector.setQuery(filterString);
PS - I tried the other way with window command as well.
Jim Coyne
This article may help you to build the query - Generate an encoded query string through a filter.
You just have to replace the values with any variables, etc...
Jim Coyne
Awesome. Thanks!
That
ref_qual_elements=
is a nice trick.
