list collector variable base if or switch condition in workflow not working.
pratikyadav
I am trying to use a table list collector variable base if or switch condition in Service Catalog workflow , where i am checking if the options selected under list collector field contain X then move to next activity to approval stage else move to fulfilment stage. But unfortunately both If and switch activity is not working. Once X selected stil it going to fulfilment stage. Below is the workflow i am using.
Ankur Bawiskar
Hi Pratik,
For this you need to use the if condition with script
answer = checkValue();
function checkValue(){
var values = current.variables.<variableName>.toString();
var split = values.split(",");
var X = sysId to be searched
var arrayUtil = new ArrayUtil();
var value = arrayUtil.contains(split, X);
if(value)
return 'yes';
else
return 'no';
Mark Correct if this solves your issue and also mark Helpful if you find my response worthy based on the impact.
Hi Pratik,
Can you please mark answer as correct, helpful if this is achieved?
