Look Up records in Flow designer not working as expected
MGR
Hi Every one,
As am using list collector variable need to get the values from list collector variable and pass the variables values to look up records action in flow designer when am passing values to the action its giving only one record please refer the below screen shot for the reference.
HI @Ankur Bawiskar,
Please look into the above it will be help full.
Viraj Hudlikar
Tera Sage
Hello @MGR
In my PDI I created dummy list collector variable reference to user table. Now when its submitted I am trying to execute flow which will iterate through value in list collector and showcase some information.
Below is screenshot to understand more in better:
1) Catalog Item form and selection done before submitting.
2) My Flow structure first get catalog variables then lookup on incident table where active is true and caller.sys_id is one of (values from list collector) directly passed then for each loop on lookup of incident records and in log statement printing value like INC number and caller name.
3) Execution results as below:
Also do check this KB https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0962340
which will be helpful to understand working of list collector during iteration.
Thanks & Regards
Viraj Hudlikar.
