Lookup Select Box service catalog variable Reference qual
Bogdan18
Hi everyone,
So I have a Lookup Select Box variable on a catalog item which is looking for the choices of the Subcategory field from the Change Request form. The Subcategory field is a string field with Choices defined and they have a dependency on the Category values.
I also set the Variable attributes to ref_qual_elements=Business Systems.
The thing is that the above doesn't work. If I look at the variable in my catalog item form I see all of the choices from the Subcategory field. I just want to see the ones depended on Business Systems. I could create a script include and a Catalog Client Script but I think this is too much for such a simple reference qual?
Any ideas why this would not work and any suggestions on hot to make it work?
thanks,
Bogdan
rad2
This the filtering is on the choice table. maybe you can create a lookup select field on sys_choice table and filter with the table - change_request and element - subcategory and dependent_value - Business Systems options
ex -
javascript: 'name=change_request^element=subcategory^dependent_value=business_systems';
I have created a test one with following details
field - category
language - es
Ok, Have you tried using 'label' instead.
Thanks again for the help provided!
It was something that I personally missed in the query and that's why it didn't work. I noticed the issue when I just went to the Choice table and created the filter manually in the list view.
Reference qual: javascript: 'name=change_request^element=u_subcategory^dependent_value=Business Systems'
Variable Attributes: ref_qual_elements=Business Systems
I will mark your answer correct so other in the same situation will see the solution!
best regards,
Bogdan
Glad it helped!!
