Mail Script URI Link Help
shawhan1126
Giga Contributor
I have the following mail script for Change Approval Reminders:
//First, we need to locate our current user's approvals (the parm1 variable contains the current approver)
var app = new GlideRecord('sysapproval_approver');                           //create a query to retrieve open approvals
app.addQuery('state','requested');        //only retrieve approvals that are pending
app.addQuery('approver',event.parm1);                                                             //only find approvals for the current approver
app.addQuery('sysapproval.sys_class_name','change_request');                     //only find approvals for change reqeusts
app.query();
while(app.next()){
//now that we have an approval for that user, we are going to look up the change tickets they need to approve and print out the data
var chg = new GlideRecord('change_request');                                     //find the first related Change approval and print info
chg.get(app.sysapproval);
template.print('<p>You have an open change approval for ' + chg.number + '</br>');
template.print('<b>Description:</b> ' + chg.short_description + '</br>');
template.print('<b>Scheduled date:</b> ' + chg.work_start + '</p>');
I would like to make the chg.number a clickable link.   I am unable to do so with ${URI_REF}.   I would rather not have a separate link that says click here and instead have the CHG number itself clickable (Screenshot below).   Any help?
//I do want the link to point to the Approval and note the Change itself //
I just noticed this.   So the link needs to be...
template.print('<p>You have an open change approval for <A href="https://yourinstance.service-now.com/nav_to.do?uri=sysapproval_approver.do?sys_id=' + app.sys_id + '">' + chg.number + '</a><BR>');
One little detail...I think chg.work_start   should be chg.work_start.getDisplayValue() so that it accounts for user time zone.   Not sure if this is relevant to you, if you have people in different time zones.
justin_drysdale
Mega Guru
Assuming you can pass the sys_id along with the change number, you can use a function to build the link:
app.query();
while(app.next()){
template.print('<p>You have an open change approval for ' + buildLink(chg.number.toString(), chg.sys_id.toString()) + '</br>');
function buildLink(n, sid) {
  var s = 'https://YOURINSTANCE.service-now.com/';
          s += 'nav_to.do?uri=change_request.do%3Fsys_id=';
          s += sid;
  var link = "<a href='" + s + "'>" + n + "<\a>";
  return link;
