Major Incident candidate trigger Rule not working properly
Aparna Gurav1
Hello Team,
I need your help for fixing below issue.
  1. I created  field on the incident form - Is this is a major incident field with choice type
  2. And I Map this field on the record producer Service Incident
  3. and then Create major incident trigger rules based on that new field = yes
If I select Is is this major incident -Yes in front end (SP)
  1. value in the backend is not populated properly. It adds a new value ‘yes’ to the choice list instead of using the existing one
  1. Also after creating incident and selecting it is a major incident, the incident still does not appear in the Major Incident Candidate list.
How to fix above issue ?
then don't use Map to field; you can use script if target field is of type Boolean
if(producer.variableName == 'yes')
	current.u_target_field = 'true';
else
	current.u_target_field = 'false';
Certified Technical Architect  ||  9x ServiceNow MVP  ||  ServiceNow Community Leader
Can reply me on below query please ?
Aparna Gurav1
How to fix above issue . How to map correct type in incident form and record producer
