Make a filter default
Andrew Meza
When I select a reference field, it displays all records active true and false. I have a filter setup called "Active". Is there a way to make this filter default when I click to select a user from my custom table?
I have the module to auto select active=true which works just fine, it's when I click on the magnifying glass to select a user that all goes away, and it gives me "All".
2 ACCEPTED SOLUTIONS
Omkar Kumbhar
Hello @Andrew Meza ,
Right click on the reference field -> configure dictionary for that Division L4 field
In the reference specification you can add the condition as Active as true which will be default set
If I was able to help you with your case, please click the Thumb Icon and mark as Correct.
Ashutosh C J
Hi @Andrew Meza
In the Dictionary of the field Division L4, you can simple add a reference qualifier condition as Active is True.
Aman Kumar S
Hi @Andrew Meza
All you need to do is to set the reference qualifier, you can have simple type and set filter condition as
Active Is True
Best Regards
Aman Kumar
