Making field mandatory for inbound integration
Ankita9
How can we make below fields mandatory for an inbound integration?
Record should be created only if below fields have validate data, Please suggest.
Mandatory Fields:
1. Display Name
2. Full Name
3. Source Identifier
4. CI Source
5. Status
6. Criticality Classification
7. CI Owner Group
8. Support Group
9. Approver Groups
10. HA Configuration
11. Environment
12. Install Status
13. Description
14. Class
Thanks in advance!!
Hi Ankita,
If you are using scripted REST API and have shared that endpoint; you can check this link where I have shared solution
Return Error Message for missing Mandatory field via Scripted Rest API
OR
if you are using import set API then you can use onBefore transform scripts; you can ignore that row
something like this
(function runTransformScript(source, map, log, target /*undefined onStart*/ ) {
	// Add your code here
	if(source.u_field1 == '' && source.u_field2 == '' && source.u_field3 == '')
		ignore = true;
})(source, map, log, target);
Hi Ankita,
OR
something like this
		ignore = true;
