Matching and replacing a part of a string..
Aravinthakumar
This is my code:
var gr = new GlideRecord('kb_knowledge');
gr.addQuery('number','KB0081186');
while (gr.next()){
gr.u_level_1= gr.u_level_1.replace("old", "new");
//or
//gr.u_level_1= gr.u_level_1.replace(/old/, "new"); //need to know the difference b/w this line and the above line
gr.update();
//Also there are many special characters like  below
gr.u_level_1= gr.u_level_1.replace(/old/g, "new");
gr.u_level_1= gr.u_level_1.replace(/old/D, "new");
Need to know the use of /g and /d characters in the replace function.
Can anyone explain more about finding a exact bit of a string and replace with other bit of string.
Ankur Bawiskar
Hi Aravinth,
it all depends on what you want to replace
/old/g means search for that word in entire string and then replace it; this uses regular expressions
replace("old", "new"); -> this will replace only first occurrence of old to new
\d is used for digit but I don't think you can use that as /old/d
what you want to replace with what?
Mark Correct if this solves your issue and also mark Helpful if you find my response worthy based on the impact.
Hi Aravinth,
the above is case insensitive search only
it will search both OLD and old and then replace
Barrilito van D
Use: gr.u_level_1= gr.u_level_1.replace("desktop", "computer");
The explanation of gr.u_level_1= gr.u_level_1.replace(/old/, "new"); is that every occurence of the string part "old" within the field u_level_1 will be replace with the string "new".
Regards!
M Prasanth
Kilo Explorer
Hi ALL ,
  let me help here .How can change FIeldName  in incident form using EXCEL file.
