Metric report to track the severity changes to any incident ticket
Karthik Reddy11
Hi all
How to Create a metric report to track the severity changes to any incident ticket
If severity changes on incident ticket it should track all records and total count how many times severity changes
Ex:
On Incident ticket the severity is 3 and if changed to severity 2 and then changed to 1 again
Then it will show all 3 changes and total count of incident severity changes
I didn't worked on Metrics till now can you help me with this
karthik
9 REPLIES 9
Please create a Database view similar to the one given in the screenshot below,
Please update the Where clause on table metric_defintion table to md_sys_id = <sys_id_of_your_metrc_definition_record>
Once done create a report from this Database view.
Hi Vasanth
Instance upgrade was done for last 10days sorry to reply late
I have created a database view when i click on try it  it is showing some error
please check below image
and also
Metric definition
Metric Instance
Instance
and How to create report from database view?
I have created direct reports and i have given filter like definition =Track severity changes(Metric definition Name)
is this correct?
Hi Karthik,
Please give the sys_id within double quote and try.
Hi Vasanth
what are the fields I have to added on
1)Metric Definition
2)Metric Instance
3)Incident
can you check where clause on above images in last chat
it is showing error
If you added any specific field in the table, Please make sure the you added definition field from metric_instance table.
