Model Name Reference Qualifier
sarahyelton
I would like to modify the out-of-the-box reference qualifier for the model field on the alm_asset table.   There is a column on the model_name table (status) where you indicate if the model is "In Production", "Retired", or "Sold".   I only want users to be able to select models that are "In Production" for new asset record entries.   This is the current script for the reference qualifier.   How do I add to it to only display models where the status value is "In Production"?   Thank you for your help.   I'm not well versed in writing scripts.
javascript:new ModelAndCategoryFilters().assetModelRefQual(current)
This is the status column.
This worked perfectly!   Thank you!!
Awesome glad this worked for you.   Can you please mark this post as answered so others viewing can benefit?
For whatever reason, it won't allow me to mark it correct.   I will try and figure out why.   Thanks again.
That's a really nice Michael Ritchie.  This should have been marked as the correct solution.  I didn't know you could do what you just did.  Great outcome.  It worked for me. Thank you.
