More than 5 child task should not be allowed to create in related list.
Star123
Hi Everyone.
I have a requirement. we have 1 parent table and 1 child table. in Parent table we have related, from where we are allowing to create child records.
Requirement is New button should get disable or Hide after 7 child records got created for Parent Record.
How we can Achieve this through List UI Control.
9 REPLIES 9
@Star123
what does this mean -> global.N.isMemberOf?
If my response helped please mark it correct and close the thread so that it benefits future readers
@Star123
are you using the correct table name, field name in that?
var grTask = new GlideAggregate("Child table");
grTask.addQuery("request_number", parent.sys_id);
Hello @Star123 ,
Use
"gs.getUser().isMemberOf(parent.assignment_group)"
instead of
"global.N.isMemberOf(parent.assignment_group)"
And please mark your question as answered, as it was about checking the number of child tasks, not checking additional conditions.
Robert
@Star123
try this
1) you are using wrong method for group membership
2) also optimized the code a bit
var answer;
var inactiveStates = ["7", "3", "24", "20"];
if (gs.getUser().isMemberOf(parent.assignment_group) && !inactiveStates.includes(parent.state) && !getAnswer()) {
    // Only active true states and not new state
    answer = false;
    answer = true;
function getAnswer() {
    gs.info("my code working");
    var lmt = parseInt(gs.getProperty('x_amspi_cpmo_res_0.max_task'));
    grTask.addAggregate('COUNT');
    grTask.query();
    var taskCount = grTask.getAggregate('COUNT');
    return taskCount < lmt;
answer;
@Star123
Hope you are doing good.
