MRVS is not working on Portal
Monika2
Giga Guru
MRVS is not working while added the same on catalog item.
It throws below error on portal and failing to load SC_Catalog_Item widget.
java.lang.NullPointerException: Value in JsonObjects name/value pair cannot be null
Failing widget: 'SC Catalog Item' (3c29786e87133200e0ef0cf888cb0bdf)
Clearing this solved the issue, right? Can you mark this answer as Correct?
Marking helpful and Correct is seen as a reward for giving helpful and correct answers.
Thank you! 🙂
22 REPLIES 22
palanikumar
Hi Monika,
Are you using any custom page? if yes, make sure you are using the widget with ID widget-sc-cat-item-v2. This is the new widget with has fix to lot of issues.
Please share the screenshot of the Portal page if this does not resolve your issue
Thank you,
Palani
I don't have any customization on Portal I am using the existing widget only.
Monika2
Giga Guru
Thanks for your help.
I am able to figure out the issue I am passing wrong value in Varaible Set Attributes field in variable set.
Removing the same resolved this issue on portal.
