Multiple sys_IDs on system property, how to call in client script to verify condition
Varun Sai
I have created system property to include about 5 countries sys_ids(India, Africa, Japan, China, Sri Lanka), would like to call this system property sys_id's in the client script, 'Country' variable is a reference field to country table.
If one of these countries is not selected then the below condition in client script it should clear the variable values.
Script Include
getPropertyCountry: function() {
        return gs.getProperty('glide.exclude.countries');  // Has 5 countries sys_id's - India, Africa, Japan, China, Sri Lanka
Client script
function onSubmit() {
        var ga = new GlideAjax('County_check');
        ga.addParam('sysparm_name', 'getPropertyCountry');
        ga.getXML(myCallBack);
        function myCallBack(response) {
            var prop = response.responseXML.documentElement.getAttribute('answer');
            var user_country = g_form.getValue('u_country');
            if (user_country !=  prop){     //only if the selected country is not any one of India, Africa, Japan, China, Sri Lanka then below conditions needs to be applied
                g_form.clearValue('u_lead');
                g_form.clearValue('c_approver');
                return false;
But I am getting an error and it's not working as the client script is not pulling the country sys_ID from the system property I think.
What am I missing here, appreciate any help.
Hi @Varun Sai
Oops. The actionName variable is missing from the script above.
	//Add these lines to your script
	if (g_scratchpad.isFormValid){
		return true;
	var actionName = g_form.getActionName();
    ga.getXMLAnswer(function(answer){
		var countries = answer;
		//If the selected User Countries is not in 5 countries
		if(countries.indexOf(user_country) == -1){
            return false;
		//Add this lines to your script
		g_scratchpad.isFormValid = true;
		g_form.submit(actionName);
	return false;
This is my script include. (Make sure the Client callable checkbox is checked)
var County_check = Class.create();
County_check.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    type: 'County_check'
Cheers,
Tai Vu
Varun Sai
Hi Tai,
I tried your solution and I am getting the JavaScript error on the portal page.
I put in alerts and didn't see the country come up on the browser too.
Not sure what's wrong.
Hi @Varun Sai
		return true;
            return false;
	return false;
Cheers,
Tai Vu
