Need advice modifying script
Wendy20
I am very new to scripting and need to advice.  How can I modify the below out of the box business rule script to synchronize "Cancel" state between Parent and child incidents?  Thank you in advanced for your advice.
updateChildIncidents();
function updateChildIncidents() {
if (current.state.changesTo(IncidentState.RESOLVED))
resolveChildIncidents();
else {
var value;
if (current.comments.changes()) {
value = deriveFieldValue('comments', gs.getMessage('Comment copied from Parent Incident'));
if (value && value != "")
executeFlowAction(current, 'comments', value);
if (current.work_notes.changes()) {
value = deriveFieldValue('work_notes', gs.getMessage('Work note copied from Parent Incident'));
executeFlowAction(current, 'work_notes', value);
function executeFlowAction (parentIncidentGr, fieldName, value) {
try {
var inputs = {};
inputs['field'] = fieldName; // String
inputs['value'] = value; // String
inputs['parent_incident_gr'] = parentIncidentGr; // GlideRecord of table: incident
sn_fd.FlowAPI.getRunner().action('global.update_child_incidents').inBackground().withInputs(inputs).run();
} catch (ex) {
var message = ex.getMessage();
gs.error(message);
function deriveFieldValue(fieldName, msg) {
var fieldRawValue = current.getValue(fieldName) + '';
var fieldValue = fieldRawValue.trim();
if (fieldValue && fieldValue.length > 0) {
if (fieldRawValue.indexOf(msg) == 0)
return (fieldRawValue);
else
return (msg + ": " + fieldRawValue);
// Resolve active, unresolved incidents that are children of the current incident
function resolveChildIncidents() {
    //check if update is valid or aborted before updating child incidents
if(current.isActionAborted())
var incident = new GlideRecord("incident");
incident.addActiveQuery();
incident.addQuery("parent_incident", current.sys_id);
incident.addQuery("state", "!=", IncidentState.RESOLVED);
incident.query();
var msg = "";
while (incident.next()) {
gs.print("Incident " + incident.number + ' resolved based on resolution of Parent Incident ' + current.number);
incident.state = IncidentState.RESOLVED;
if (incident.isValidField("close_notes") && incident.close_notes.nil()) {
msg = gs.getMessage('{0} copied from Parent Incident', current.close_notes.getLabel());
if (current.close_notes.toString().indexOf(msg) == 0)
incident.close_notes = current.close_notes;
else
incident.close_notes = msg + ": " + current.close_notes;
if(incident.isValidField("close_code"))
incident.close_code = current.close_code;
msg = gs.getMessage("Resolved based on resolution of Parent Incident.");
if (current.comments.toString().indexOf(msg) == 0)
incident.comments = current.comments;
else
incident.comments = msg + " " + current.comments;
incident.work_notes = current.work_notes;
incident.update();
Saurabh Gupta
HI,
You can try bel
else if(if (current.state.changesTo(IncidentState.CANCELLED)))
cancelChildIncidents();
else {
var value;
try {
var inputs = {};
} catch (ex) {
gs.error(message);
else
incident.query();
var msg = "";
else
else
incident.update();
function cancelChildIncidents() {
incident.addQuery("state", "!=", IncidentState.CANCELED);
incident.query();
var msg = "";
incident.state = IncidentState.CANCELED;
msg = gs.getMessage("Canceled based on cancelation of Parent Incident.");
else
incident.update();
ow script-
Thanks and Regards,
Saurabh Gupta
Vishal Birajdar
Hello @Wendy20 ,
There is OOTB business rule on incident table "Sync Child Incident State"
You can refer this BR and you will get the solution.
Vishal Birajdar
ServiceNow Developer
- Socrates
