Need help hiding a Workspace button based on reference record and logged-in user
dd31
I have created a button on Workspace using the Button component. I want to hide it based on two conditions:
The current record where the button appears has a reference in a specific table
The Assigned to field of current record should match the logged-in user.
Here’s what I did so far:
Created a Data Source (Transform ) to check these conditions.
Called that data broker from the Hide component visibility property of the button.
However, it’s not working as expected — the button isn’t hiding even when the conditions should match.
Could someone help me figure out what I might be doing wrong?
PFB SS for reference:
Thanks @Ankur Bawiskar ! I figured it out, the issue was that my Data Broker was pulling the assigned_to from another source where the record wasn’t being fetched properly. I removed that property from the Data Broker and used the correct source, and now the button visibility works as expected.
Shruti
Did you create an ACL for new data resource?
If not, create an ACL
Type - ux_data_broker
Operation - execute
Name - sys_id of data resource
Assign relevant role
Reference - https://developer.servicenow.com/dev.do#!/learn/courses/xanadu/app_store_learnv2_uibuilder_xanadu_ui...
i did, still not working
Ankur Bawiskar
@dd31
I am not that much familiar with this but did you add gs.info() and debug?
yes
function transform(input) {
    try {
        var userSysId = gs.getUserID();
        gs.info("Transform Debug: Input assignedtosysid=" + input.assignedtosysid +
            ", recordsysid=" + input.recordsysid + ", userSysId=" + userSysId);
        var grci = new GlideRecord("x_g1001_competitiv_competitive_intelligence_table");
        grci.get(input.recordsysid);
        var vassignedsysid = grci.getValue("assigned_to");
        if (vassignedsysid == userSysId) {
            var grteam = new GlideRecord('sn_tcm_collab_hook_ms_teams_chat');
           // grteam.addQuery('source', input.recordsysid);
            grteam.query();
            if (grteam.next()) {
                gs.info("Transform Debug: Matching record found → show button");
                return false;
        gs.info("Transform Debug: No match → hide button");
        return true;
    } catch (ex) {
        return {
            error: true
