Need help on creating notification
Pradeepa B
Requirement is when incident sla (Business elapsed percentage is greater then 75%) and when incident assignment group is ABC1 or ABC2, email should trigger to particular users + incident assignment group(only which group members have title as contractor)
Could you please help me on this requirement?
Thank you
16 REPLIES 16
Pradeepa B
Hi @Ankur Bawiskar ,
Requirement is when incident sla (Business elapsed percentage is greater then 75%) and when incident assignment group is ABC1 or ABC2, email should trigger to particular users(tester1 and tester2) + incident assignment group(only which group members have Employment Status as contractor).
I have created the notification, when to send as event is fired.
Created the event registry and pulled in even name in the notification.
I have created the business rule,
Business rule script:
(function executeRule(current, previous /*null when async*/) {
    var recipients = [];
    // Safely get the assignment group record
    var group = current.task.assignment_group.getRefRecord();
    if (!group || !group.sys_id) {
        gs.log("[Contractor Notify] Invalid assignment group on incident: " + current.number);
    // Query group members
    var grMember = new GlideRecord('sys_user_grmember');
    grMember.addQuery('group', group.sys_id);
    grMember.query();
    while (grMember.next()) {
        var user = grMember.user.getRefRecord();
        if (user && user.edu_status == 'C') { // Employment Status is Contractor
            if (user.email) {
                recipients.push(user.email.toString());
    if (recipients.length > 0) {
        // Trigger custom event with recipient list
        gs.eventQueue('sla.75percent.notification', current, group.sys_id.toString(), recipients.join(","));
        gs.log("[Contractor Notify] Event triggered for: " + recipients.join(", "));
    } else {
        gs.log("[Contractor Notify] No contractors found in group: " + group.name);
})(current, previous);
Could you please help me on this requirement and script?
Thank you
@Pradeepa B
so what logs did you add and debug?
Unless you debug you won't know which line is breaking your script
Pradeepa B
Notification is working fine, but it's triggering every 2%, how to fix this issue?
@Pradeepa B
Glad to know that my scripted helped you achieve your requirement.
@Pradeepa B
when should the email be sent?
you should ensure you configure the correct BR conditions
