Need help to exclude weekends from the calculation
MR1
The below script is working as expected but I need help to modify and remove the weekend from the calculation.
The below advance script is on the calculated tab of field "Aging". The integer type field 'aging' is on scoped application.
(function calculatedFieldValue(current) {
	if(current.state == 7){ //7 is closed value of state field on a scoped application
		var aging= GlideDateTime.subtract(new GlideDateTime(current.sys_created_on),new GlideDateTime(current.closed_at));
		aging= GlideDateTime.subtract(new GlideDateTime(current.sys_created_on),new GlideDateTime());
	return aging.getDayPart();
})(current);
@MR1
I'm not sure  how you added my code to you instance , I tried and it  works well.
See my pics below.
start end and  agingstart end and agingCalculation scripts on field  "Aging"Calculation scripts on field "Aging"test1test1test2test2
@MR1
In my country holiday changes every year.....
I think you need a table to store the holidays,and get the holiday infomation from the table at the first. and modify the below part to judge if it's a holiday....
 if( startDateTime.getDayOfWeekUTC() == 6 || startDateTime.getDayOfWeekUTC() == 7){
