Need help to update comments from jira to servicenow using jira spoke
Naveen34
I have created an integration between servicenow and jira using jira spoke, but while I'm trying to updated comments from jira to servicenow I'm not able to do that as the body of the comments are not being updated.
even tried one KB article from support team : https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0830760
but could not understand that, can anyone help me to implement the process mentioned in the link.
TIA.
Ravi9
Could you tell me which part of the support kb article you didnt understand or you are stuck with ?
Naveen34
Hi Ravi,
I couldn't understand Resolution part.
They mentioned that we need to extract the values for the body tag from the comments tag and then pass this as an input to the next action which updates the work notes. Is it something we need to create a new input?
the entire resolution part is confusing for me including the code, Could you please simplify it for me.
TIA
Ravi9
I dont have jira spoke installed or configured
But i would assume something like below , also assuming you know how to use flow , below is a sample , you will have to take cue and make it work
first create an action with below input and script and output
and then add the action in your flow / subflow
once thats done then you can update work notes or whatever you want from it
Naveen34
Thank you for the response,
I have followed your steps but still getting an error
