Need help to write UI Policy Script for a custom created field visibility
Snow Angel
I need to write a script for a custom created field's visibility (custom field name "Justification"). It needs to be displayed and become mandatory must only if "Score" field is manually updated. The condition builder does not have options for "Score" manual update.
Can someone help me write this script? I am new to scripting. Thanks
So:
Since the only other means that updates the Demand most likely take place on the server-side(business rules, flow, workflows - potentially UI actions etc) you should not be concerned about how you can identify if this was updated manually.
However, I would write an onChange Client Script for the field "score" which states the following:
if (newValue == '')
else {
g_form.setVisible('justification',true);
g_form.setMandatory('justification',true);
Please give it a try and provide feedback.
Tudor
Tudor
Since UI Policy is front end the question arises: how else is Score being updated on the front-end besides user input(either direct or indirect)?
Score is being updated directly/automatically as "demand" is going through different stages as in screening, qualified and approved. The score populates itself but if its changed in the field manually , the new field "Justification" needs to appear.
So:
if (newValue == '')
else {
Tudor
Thank you so much Tudor! Its working.
I wrote the onChange Client Script as you had suggested. However, the "justification" field was always appearing so I created a UI Policy with no conditions, and added a UI Action (on load) to set the "justification" field visibility to "false". And it works.
Again mucho gracias 🙂 You Rock 🙂
