Need to create a bidirectional integration between two Snow instances by using OOB table API
shashank32
Giga Contributor
Hi
I need to create a bidirectional integration between two Snow instances by using OOB table APIin
ex if i create or update a incident in source instance it should create or update incident in target instance and viceversa.
Can anyone help me in doing this.
Thank You
Shashank  K S
Ankur Bawiskar
You can use OOB Table API methods.
Refer below link for step by step instructions
ServiceNow to ServiceNow Integration using REST API and PUSH and PUT methods with Business Rule
You can also explore on Ebonding Spoke with less scripting
ServiceNow eBonding spoke
Refer the below link which has the approach with example shared by me.
Integration hub ebonding spoke
12 REPLIES 12
It's working fine . Thank you
You are welcome.
Gaurav Shirsat
Hi Shashank
you already have lot of links of Docs  from other experts. those looks enough.
please refer the video
https://www.youtube.com/watch?v=Hob80gcVqi0&t=26s
https://docs.servicenow.com/bundle/paris-application-development/page/build/applications/concept/api...
Please Mark Correct and Helpful
Thanks and Regards
Gaurav Shirsat
