Need to display the select box values based on another select box
Srvs
Hi
please help me to display the select box values based on another select box   in a catalog item form.
for example i need to display the "states" based on "country" in catalog item form... please help me..
venky
Srvs
by using above i created two dropdowns.
g_form.clearOptions('B'); is not working in first time,
i am getting all the fields in 2nd dropdown at first time. after changing the value in 1st dropddown it is working.
pleas help me to resolve.
venky
You can have a default value as "None" for the first Select Box and you can hide the Second Select Box when First one is None using Catalog UI Policy. Post which if the User selects any value from the first Select Box you can display the corresponding values in Second Variable based on the script as Harish Provided above.
Hope this helps.Mark the answer as correct/helpful based on impact.
Shloke
Shloke
Hi Venkatesh,
If i am not wrong you had same requirement on the below thread.
display dropdown field based on another, g_form.clearOptions('B'); is not working
Let me know if you have any further question.
Harshvardhan
Please like, mark as correct/helpful if it is right.
Hi Venkatesh,
Can you try like below.Below script will work in onload well and it will set the first time
g_form.clearOptions('city');
var getCountry1 = g_form.getValue('country'); // country is variable name
  alert(getCountry1);
if(getCountry1=='India')
  g_form.addOption('city','Bangalore','Bangalore'); // city is variable name, bangalore is the choices in your select box
  g_form.addOption('city','Chennai',' Chennai');
    else if(getCountry1=='Aus')
  g_form.addOption('city','Brisbane','Brisbane');
var getCountry = g_form.getValue('country'); // country is variable name
  alert(getCountry);
if(getCountry=='India')
    else if(getCountry=='Aus')
