Need to help on scripting
Khalid9030
Hi Team,
I have written below script in background script the purpose of the script is Group incidents by assigned to and list only grouped records where the assigned to have more than one record. The error i am getting is
invalid return
var agg = new GlideRecord('incident');
agg.addAggregate('COUNT','assigned_to');
agg.query();
var arr =[];
while(agg.next()){
          var incidentCount = agg.getAggregate('COUNT','assigned_to');
          if(incidentCount >1) {
                   gs.info('Display  the count',[incidentCount])
                   inc.addQuery('assigned_to'+agg.assigned_to);
                   inc.query();
                   while(inc.next()){
                             arr.push(inc.sys_id.toString())
     return arr;
          gs.print([incidentCount]);
swathisarang98
@Khalid9030 ,
The code which you have written will not satisfy your requirement, i have modified the entire code ,Please refer the working code as below,
var agg = new GlideAggregate('incident');
agg.addAggregate('COUNT', 'assigned_to');
agg.orderBy('assigned_to');
agg.query();
var incidentCount = 0;
while (agg.next()) {
    var num = [];
    incidentCount = agg.getAggregate('COUNT', 'assigned_to');
    if (incidentCount > 1) {
        gr.addQuery('assigned_to', agg.assigned_to);
        while (gr.next()) {
            num.push(gr.getValue('number'));
        gs.info('count for ' + agg.assigned_to.name + ':' + incidentCount + " Incident Numbers : " + num );
Please mark this comment as Correct Answer/Helpful if it helped you.
Swathi Sarang
swathisarang98
Hi @Khalid9030 ,
There were few errors in the code i have corrected it please do give it a try ,
agg.query();
var arr = [];
var num = [];
if(agg.next()) {
    var incidentCount = agg.getAggregate('COUNT', 'assigned_to');
        gs.info('Display the count: ' + incidentCount);
        inc.addQuery('assigned_to' , agg.assigned_to);
        inc.query();
        while (inc.next()) {
            arr.push(inc.sys_id.toString());
            num.push(inc.getValue('number'));
    gs.print('array : ' + arr);
    gs.print('Number : ' + num);
Swathi Sarang
dgarad
Tera Sage
Hi @Khalid9030
 try the
var incidentCount =0;
var arr=[];
var assginto=[];
agg.query();
while(agg.next()){
assginto.push(agg.assigned_to.toString());
 gs.print('Display the count'+incidentCount);
    inc.addQuery('assigned_to' , assginto);
    inc.query();
	gs.print(arr);
    return arr;
below code.
If my answer finds you well, helpful, and related to the question asked. Please mark it as correct and helpful.
dgarad
Sohail Khilji
@swathisarang98  yes you own the right , credits to you... 🙂
☑️ Please mark responses as HELPFUL or ACCEPT SOLUTION to assist future users in finding the right solution....
LinkedIn - Lets Connect
Hello @Sohail Khilji ,
Can you please let me know what is the difference in my  below code and your code?
I can see only variable names and info texts are changed .And more over its not the working code yet as i re-tested it once again and was about to post the correct code
Swathi sarang
