Need to help on scripting
Khalid9030
Hi Team,
I have written below script in background script the purpose of the script is Group incidents by assigned to and list only grouped records where the assigned to have more than one record. The error i am getting is
invalid return
var agg = new GlideRecord('incident');
agg.addAggregate('COUNT','assigned_to');
agg.query();
var arr =[];
while(agg.next()){
          var incidentCount = agg.getAggregate('COUNT','assigned_to');
          if(incidentCount >1) {
                   gs.info('Display  the count',[incidentCount])
                   inc.addQuery('assigned_to'+agg.assigned_to);
                   inc.query();
                   while(inc.next()){
                             arr.push(inc.sys_id.toString())
     return arr;
          gs.print([incidentCount]);
swathisarang98
@Khalid9030 ,
The code which you have written will not satisfy your requirement, i have modified the entire code ,Please refer the working code as below,
var agg = new GlideAggregate('incident');
agg.addAggregate('COUNT', 'assigned_to');
agg.orderBy('assigned_to');
agg.query();
var incidentCount = 0;
while (agg.next()) {
    var num = [];
    incidentCount = agg.getAggregate('COUNT', 'assigned_to');
    if (incidentCount > 1) {
        gr.addQuery('assigned_to', agg.assigned_to);
        while (gr.next()) {
            num.push(gr.getValue('number'));
        gs.info('count for ' + agg.assigned_to.name + ':' + incidentCount + " Incident Numbers : " + num );
Please mark this comment as Correct Answer/Helpful if it helped you.
Swathi Sarang
swathisarang98
@Khalid9030 ,
agg.query();
    var num = [];
        while (gr.next()) {
Swathi Sarang
