Need to visible "Add" button in related list in problem form when state is closed
Asha Pathak
When state is new , it shows the Add button in related list
But when state is closed , it does not show the Add button on related list
Is there any way to show Add button in related list when state is closed
2 ACCEPTED SOLUTIONS
Hi @Asha Pathak I am using OR condition here so as long as the parent table is problem, the 1st condition (parent.sys_class_name == 'problem') will execute and will ignore the other condition (parent.active == true), for other tables the parent.active will be true. this way there is no impact for other tables and condition works as expected.
Does it work? If yes please accept the solution:)
Harish
HI @Asha Pathak after checking itseems OOB servicenow you cannot add a CI to the closed records, we would need to do a changes to the OOB script include AssociateCIToTask.
Modified script:
    script include: AssociateCIToTask
function to modify: _isValidTask
    _isValidTask: function(id) {
        var gr = new GlideRecord('task');
        //return gr.get(id) && gr.active; // need to remove gr.active here to add Ci
        gs.info("ID==>"+ gr.get(id));
        return gr.get(id);
After modifying the above function CI gets added to the closed records
Harish
26 REPLIES 26
Hi @Harish KM I want to display Add button in related list only is problem state is closed
If we made changes , then is it affect other functionality?
@Harish KM means now if problem state is new, it shows the Add button but if state changes to closed , it does not show the Add button
@Harish KM Can we write any business rule for it?
Hi @Asha Pathak I tot you want to show add button on incident table?
What condition do you have on add UI action for problem?
Harish
@Harish KM
Here is the problem form and below are related list, for this related list I have to add Add button when problem state is closed
