Need to visible "Add" button in related list in problem form when state is closed
Asha Pathak
When state is new , it shows the Add button in related list
But when state is closed , it does not show the Add button on related list
Is there any way to show Add button in related list when state is closed
2 ACCEPTED SOLUTIONS
Hi @Asha Pathak I am using OR condition here so as long as the parent table is problem, the 1st condition (parent.sys_class_name == 'problem') will execute and will ignore the other condition (parent.active == true), for other tables the parent.active will be true. this way there is no impact for other tables and condition works as expected.
Does it work? If yes please accept the solution:)
Harish
HI @Asha Pathak after checking itseems OOB servicenow you cannot add a CI to the closed records, we would need to do a changes to the OOB script include AssociateCIToTask.
Modified script:
    script include: AssociateCIToTask
function to modify: _isValidTask
    _isValidTask: function(id) {
        var gr = new GlideRecord('task');
        //return gr.get(id) && gr.active; // need to remove gr.active here to add Ci
        gs.info("ID==>"+ gr.get(id));
        return gr.get(id);
After modifying the above function CI gets added to the closed records
Harish
26 REPLIES 26
@Harish KM
It shows Add button , but no records are added in related list
Hi @Asha Pathak Records will not show, you need to click on add button to add ci to the list.
Harish
@Harish KM After clicking , it will not show
@Harish KM After clicking, It works for incident and change , but not for Affected CIs and service offering
Modified script:
        return gr.get(id);
Harish
