02-21-2024 02:05 AM - edited 02-22-2024 08:00 PM
Hello Team,
When I open the Form to add the fields to view, then after dot walk the OOTB field is available to add but custom field on Computer form is not available to add. The field is not available in slush bucket.
I can easily add the OOTB field from Computer to form view but I am not able to add the field. Even when I to table through field, the field is not available after expansion.
Please suggest.
02-21-2024 05:05 AM
Hi @Asmita7
I tried this, seems you created custom field on computer table so it will not show , you need to create on CMDB_CI table , bcz computer is child.
02-21-2024 05:05 AM
Hi @Asmita7 ,
Did you try doing like this
Go to Form Layout from the form header, then select the Section from Form view and section. You should be able to see the custom fields here.
02-21-2024 04:51 AM - edited 02-21-2024 04:51 AM
02-21-2024 05:05 AM
Hi @Asmita7 ,
02-21-2024 05:43 AM
Hi @Anubhav24
I checked but it is not displaying.
