On load client script for applying Change template not working through Related lists
Deepansh Jain
Hello ,
I have created a template and  have applied an 'on load' client script, which when a new change form is loaded the template is applied ,
My 2 additional requirements are
1. CRs created from any related list (ex: parent RITM), template is not getting applied
2. Copy change functionality not working
Currently using this Client Script-
function onLoad() {
if(g_form.getValue('type') == 'normal' || g_form.getValue('type') == 'emergency'){
if(g_form.getValue('number') == ''){
var template = g_scratchpad.Mytemplate;
//Apply the selected template
applyTemplate(template);
MrMuhammad
Please try below.
function onLoad() {
var sysId = getParmVal('sys_id');
var tiny = getParmVal('sysparm_tiny');
gs.addInfoMessage(tiny);
 if(g_form.isNewRecord() && (sysId == '-1' || tiny != '')){ // check whether the record is new and not creating from copy chang
// get and parse URL paramters
function getParmVal(name) {
 alert(name);
	var url = document.URL.parseQuery();
	alert(url);
	if (url[name]) {
		alert(url[name]);
		return decodeURI(url[name]);
		return '';
Hey Deepansh - Let me have a look.
sure
