OnChange Catalog Client Script
jay1111
Hi Experts,
I need a help on this catalog client script. Script looks ok to me, bit it is not working on portal.
		if(g_form.getValue('account') == 'Service Account'){
		g_form.setVisible('service_account_link', true);
		g_form.setReadonly('service_account_link', true);
		alert('Service Account');
I want to add more conditions to the if condition like.
 if((g_form.getValue('account') == 'Service Account') || (g_form.getValue('account') contains 'offshore') ||(g_form.getValue('account') startwith 'billing'))
Jay
Hi @jay1111 ,
You can use in built Javascript methods like startsWith() and includes().
var str = g_form.getDisplayValue("account");
if(str.startsWith("billing") || str.includes("offshore")){
alert("Service Account");
Get display value of reference field
Also one more thing to check is UI type in Client script should be set to All
I did it.
		//g_form.setDisplay('service_account_link', true);
		//g_form.setReadOnly('service_account_link', true);
 I even tried, just adding only alert. But, still not working.
Jay
is account a reference field? Then g_form.getValue('account') will return the sysid. So you cant compare it with a value 'Service Account'. In such case use UI policy or if you want to use client script, use sys_id.
Yes it a reference field and it worked when I used sysID. But, how can I achieve if Account Name contains "offshore"  or startwith "billing".
Jay
Hi @jay1111 ,
