10-30-2019 06:13 PM
I have an onChange client script that is not working the way it should. I am trying to notify users that the maximum numbers allowed is 10 digits (if they are trying to enter more than 10). I also want the variable to allow only integer. Below is what i have but its not working properly.
var parsed = g_form.getIntValue("variable_name");
//if "Not a Number", clear the parsed value
if (isNaN(parsed)){
parsed = "";
if (parsed != newValue) {
alert("Please enter a valid integer number ");
g_form.setValue("variable_name", parsed);
//if more than 10
if(parseInt(newValue) > 10){
alert(getMessage("10 digits max"));
g_form.setValue("variable_name", '');
return false;
Thank you.
10-30-2019 07:12 PM
You can try onchange script provided by Kunal or
You can use variable attributes to set the max_length on the variable to stop user from entering more than 10 characters. Then, you use on change client script to validate entered characters are integers only.
var regexp = /^([0-9]+[0-9])/;
if(!regexp.test(newValue)) {
alert('Please enter a 10 digit number');
g_form.setValue('variable name',''); // set variable to empty
If I answered your question, please mark Correct/Helpful.
10-30-2019 09:54 PM
Hi
Only for characters it would go something like this -
var regexp = /^[a-zA-Z]+$/;
alert('Please enter only characters');
Mark correct answer and close this thread if it helps.
Omkar Mone
