One way encryption
alizaman
How one way encryption works in the system.
I have set the password field to one way encryption, but could still decrypt it back to plain text.
Using the GlideEncrypter();
Encrypt var kryp = new GlideEncrypter();
var krypPas = kryp.encrypt(user_password);
gr.u_password_array = krypPas; // save password to one-way password field on table
OR
There is a Pwd Change - Local ServiceNow workflow which uses another method which stores password in the user table, where password cannot be decrypted back to plain text.
But what if I want to save passwords in another table/field other than user table, so very little information on user.authenticate method is available for it to be used somewhere else.
var enc = new GlideEncrypter();
var decryptedOldPassword = '' + enc.decrypt(workflow.inputs.u_old_password);
var authed = user.authenticate(userName, decryptedOldPassword);
Ali
15 REPLIES 15
To set a password, you need to use setDisplayValue...see the below post
https://community.servicenow.com/community?id=community_question&sys_id=181d4b69db9cdbc01dcaf3231f9619ed
In a scoped app you may need to get the GlideElement object first but the post shares the details.
Hi Joe,
what a speedy answer 🙂
It is what I search.
Thank you very much
NT
Joe McCarty1
Can you share a screenshot of the dictionary form of your custom password field?
Hi Joe, This is the field, i can decrypt the value back to plain text .
My best guess is that the behavior is an artifact of the use of GlideEncrypter which should be unnecessary with a one way hashed field.   I believe it is bypassing the hashing because it recognizes it as an encrypted value.   Try doing this instead and I think you won't be able to recover the value:
gr.get('user_name','employee');
gr.u_custom_password.setDisplayValue('clear_text');
gr.update();
gs.print('Verifying hash...' + gr.u_custom_password);
//Attempt to decrypt
var krypPas = kryp.decrypt(gr.u_custom_password);
gs.print('After Decrypt attempt...' + krypPas);
