One way encryption
alizaman
How one way encryption works in the system.
I have set the password field to one way encryption, but could still decrypt it back to plain text.
Using the GlideEncrypter();
Encrypt var kryp = new GlideEncrypter();
var krypPas = kryp.encrypt(user_password);
gr.u_password_array = krypPas; // save password to one-way password field on table
OR
There is a Pwd Change - Local ServiceNow workflow which uses another method which stores password in the user table, where password cannot be decrypted back to plain text.
But what if I want to save passwords in another table/field other than user table, so very little information on user.authenticate method is available for it to be used somewhere else.
var enc = new GlideEncrypter();
var decryptedOldPassword = '' + enc.decrypt(workflow.inputs.u_old_password);
var authed = user.authenticate(userName, decryptedOldPassword);
Ali
15 REPLIES 15
Hi Gaetano Di Mitri
If I am not mistaken you can do nothing to decrypt and read a users current password.
I guess the best way of creating and maintaining sufficient password security is by using 3rd part services as SSO or LDAP.
Mikkel
