‎08-03-2020 12:08 PM
Hello All,
I'm trying to fix orderguide issue , after form filled try to click on 'next ' button ..its not moving and showing below error on console "the server respond with a status of 400"
tried to check any mandatory field is hidden..but non of them identify ..
https://hi.service-now.com/kb_view.do?sysparm_article=KB0684628
can any one help me on this?
‎08-04-2020 06:49 AM
Issue has been fixed
https://community.servicenow.com/community?id=community_question&sys_id=0dcf3fef1bd97b00ada243f6fe4bcb5e
‎08-03-2020 12:17 PM
Do you have catalog client scripts? Have you checked your console log to see if there's any errors on the scripts?
Berny
‎08-03-2020 12:18 PM
Keep in mind that catalog client scripts could be associated to variable sets or order guides, you will need to check all the ones that apply to see if one is failing.
Berny
‎08-04-2020 01:30 AM
i can see below error
‎08-04-2020 01:38 AM
Check the Scripts included in your Service Portal Theme. It is looking for a cross-site script but cannot find it.
Try in incognito or another browser, as it could possibly be a plugin.
