Pass values from a variable set using a client script
‎07-15-2013 08:47 AM
I'm trying to use a variable set to capture basic contact information (requested_for, phone, email) to apply to multiple catalog items. I want to be able to pass these values onto the Requested Item that is created (at least the requested_for). I created the following catalog client script that applies to the variable set, however it is just not working.
When I open the item; the requested_for will default to the person logged in. However, if I change that value to someone else...it is not passed along onto the RITM. Any help is appreciated.
if(!isLoading){
var userid = g_user.userName;
var newid = g_form.getValue('requested_for');
var cart = new GlideRecord('sc_cart');
cart.addQuery('user.user_name', userid);
cart.query();
if (cart.next()) {
cart.requested_for = newid;
cart.update();
Service Catalog
‎07-15-2013 04:15 PM
I haven't had to use a client script for this, and I use a similar 'user info' variable set on my catalog items. Do you have cascading variables turned on on your Order Guide?
‎07-15-2013 05:35 PM
It's not on an order guide...rather on single items that produce a single request with one RITM.
‎07-15-2013 10:28 PM
I am just curious to know, why are you using Client script to set the value of requested_for. You must have the workflow running for your request items. If you have a workflow running on your requested_item table, put the following script in the run script activity in your workflow itself just after the begin box.. It will set the requested_for value.
var reqRecord = current.request.getRefRecord();
reqRecord.requested_for = current.variable_pool.requested_for;
reqRecord.update();
I have done it on demo21 : https://demo021.service-now.com/com.glideapp.servicecatalog_cat_item_view.do?sysparm_id=10b44eb6c6112276005acf13b5c13274&sysparm_link_parent=109cdff8c6112276003b17991a09ad65
I hope this would help!!!
Regards/Neetu
‎07-16-2013 04:47 AM
Neetu...I was using a client script as I was not sure as to what was the best approach. I wanted to avoid using multiple scripts for each item, however using the workflow seems to work out great! Thanks for your help!!!
