Populate incident description with record producer variables
AP30
I am looking to populate incident description based on the variable selected from the record producer. Currently, the script is working as it should but because I have several select box type variables for zone, I am not able to get others to populate in the description field except one zone
Script:
current.description = '\n Comment:     ' + producer.description + '\n Target is Located at: ' + producer.target + '\n Zone is:   ' + producer.red_zone;
What i am having issues with is populating the description field based on the selected zone. The above script works well for red_zone but i have green_zone, yellow_zone, blue_zone, white_zone and brown_zone and trench_zone and i want the description field to show when any of the other zones is selected. Please provide guidance
Thank you.
Pooja Mallikarj
Try this.
var zones=' ';
if(producer.red_zone)
zones=zones+producer.red_zone;
if(producer.yellow_zone)
zones=zones+' '+producer.yellow_zone;
So on...
current.description = '\n Comment:     ' + producer.description + '\n Target is Located at: ' + producer.target + '\n Zone is:   ' +zones
Pooja M
Var zones="";
zones=zones+producer.red_zone+" ";
} if(producer.green_zone)
zones=zones+producer.green_zone+" ";
Check.this one.
Pooja Mallikarj
Try this.
var zones=' ';
So on...
Pooja M
I have tried and it is working fine in my PDI.
Thanks Pooja, This worked fine.
