Populate users with comma separated in a String field
Lucky1
Hi folks,
on the request form, there are 2 fields, "Requester" which is of type reference and "Users List" which is of type String. When i select a user in the requester then in the Users List field, his user ID should populate and the Requester field should get cleared. Another time if you select other user, then the Users List field should populate with that value too with comma separated.
Note: The user which we have already selected should not populate again when we try to select him again. It should give alert like "you have already selected the user"
So for my above query, i am showing an example here:
If i select Abel Tuter in Requester field, then the Users List field should populate with Abel.Tuter, Now if you select Dean james then the Users List field should look like Abel.Tuter,Dean.Jones
Like this the Requester field should be cleared and the selected users should populate in the Users List field with comma separated. No duplicates should come.
I tried with get Reference method, and i am able to populate Users List field with only one value. I think we have to use for loop and an array to store those selected values.
Can some one please give me code for this above task
regards,
Lucky
18 REPLIES 18
rahulpandey
Ideally you should use list type field(similar to watchlist). However below code should help(considering user list field name is u_user_list)
Type : On change
Field : Requestor
    var caller = g_form.getReference('requestor', getRequestedInfo);
    function getRequestedInfo(requestor) {
        var existingList = g_form.getValue("u_user_list");
        var newList = [];
        if (existingList.length > 0) {
            newList = existingList.split(",");
			if(newList.indexOf(requestor.name) < 0){
            newList.push(requestor.name);
            g_form.setValue("u_user_list", newList);
			else
	g_form.addErrorMessage("you have already selected the user");
        } else
            g_form.setValue("u_user_list", requestor.name);
    g_form.setValue("requestor", "");
Hi Rahul, Thanks very much for the code. I will try it and let you know. But as you mentioned, is there any field I can use as list collector on the Request form? Regards, Lucky
Hello Rahul,
I used your script but its not working. If i select Abel Tuter then at the first time, Users List field is populating with undefined,Abel Tuter and later when i select alene Rebeck, then the updated field value is undefined, Alene Rebeck which means Abel Tuter is replacing with Alene Rebeck
and other thing is, in this line of code
inplace of requestor, i feel we need to add caller bcoz, it is the variable holding get Reference method in your script.
Lucky
Hi Lucky,
the code works just fine, below is my environment code:
Requestor field name : requested_for
user list : user_list
Change the field names as per your imlementation;
    var caller = g_form.getReference('requested_for', getRequestedInfo);
        var existingList = g_form.getValue("user_list");
        var newList = [];
            g_form.setValue("user_list", newList);
			else
        } else
            g_form.setValue("user_list", requestor.name);
    g_form.setValue("requested_for", "");
find_real_file.pngAlso, there is a field type glide list, you can refer watch list field for example.
No rahul, its not coming:
and my Script is:
