Post button is not visible on sc_task
DreDay3000
Hello. The Post button next to Additional Comments, in the Notes section on the SC_task form is not showing on open an catalog task form. No seeing any UI Action for this button or any UI Policies that would hid this button. Any help is greatly appreciated.
Raghav Sharma24
Giga Patron
@DreDay3000 POST is not a UI action and it cannot be hidden from UI policy.
 Refer  SN support article to fix this: https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB1637960
If this does not fix, check if you have access to write this record(ACLs).
Please mark the answer correct/helpful accordingly.
Hello Kilo Sage, I have tried each of these and none resolve the issue:
I have tried:
set the system property to TRUE: glide.activity.compose.can_post_mandatory_fields
modify system property by adding work_notes to the value field: glide.ui.cmdb_ci_service_discovered_activity.fields. Work notes was already in the value
create UI Formatter on sc_task
