Prevent adding comments on portal
Nishant16
How to prevent Admin users from adding additional comments on a closed incident from the portal.find_real_file.png
OOB: this gets disabled for non-admin users, not for admin. I am finding it difficult where to check in platform what ACL is governing this?
once incident becomes closed or resolved it becomes inactive.
there must be some OOB table level WRITE ACL which allows only admins to write to inactive incidents
please check these all are admin overrides so admin can write active/inactive incidents
12 REPLIES 12
Ankur Bawiskar
Please check if any field level WRITE ACL is allowing admins to edit comments
Search as this and check those
Nishant16
@Ankur Bawiskar i am seeing the same ACL as in the screenshot attached, and no explicit conditions found.
On Platform the Comments gets hidden from Admin as well where there is a UI policy governing the read only on closed state.
But question is how the non admin users are restricted for adding comments on portal OOB? i would like to use the same to restrict admin as well.
for all 3 write ACLs you can update condition as
State is not closed/resolved
OR another way is to clone the widget and make the changes
https://community.servicenow.com/community?id=community_question&sys_id=e3e8c072db9997000e3dfb651f96...
We are on Paris release and using standard ticket tab widget, also when i try to create a new ACL with adding condition active is true , still i dont get the desired ouutput
then you need to update the widget and clone it and update the logic
