Problem & Change Application is not visible from Navigation Pan in Australia instance, Please help
aravind1patil1
Dear Servicenow community friends
I have configured Australia Instance from https://developer.servicenow.com
From Navigation, I can see Incident Application
All -> Incident -> All (To view list of Incidents)
Problem Statement:
I cannot see: Problem, Change applications from Navigation pan (Attached Image for your reference)
All -> Problem -> All
All -> Change Request -> All
Workaround is available:
Below commands works fine from Navigation Bar
problem_list.do
change_request_list.do
Expected Behavior:
How to resolve this issue to make visible: Problem & Change Applications from Navigation -> All
Dr Atul - LNG
Hi @aravind1patil1
Latest Recommendation
If the above troubleshooting steps do not resolve the issue, install the following application:
SOW ITSM Advanced Applications
This application includes:
Change Management
Problem Management
Major Incident Management (MIM)
On-Call Scheduling
Walk-up Experience
Application ID: sn_sow_itsm_adv_ct
Recommended version: 9.1.1 or lower
Installing this application may enable the required Change Management and Problem Management capabilities in the PDI.
Dr Atul - LNG
Hi @aravind1patil1
Change Management
Problem Management
On-Call Scheduling
Walk-up Experience
Tanushree Maiti
Hi @aravind1patil1
Just Repair the Problem and change management plugin and Try . Your problem will be resolved.
Problem Management plugin [com.snc.problem]
Change Management - Core plugin (com.snc.change_management)
AndersBGS
Hi @aravind1patil1
have you ensured that the pluggin is installed from the application manager.
aravind1patil1
@Dr Atul - LNG Thanks much. It resolved my issue
