Promote ATF suites
09-10-2025 06:38 AM
I have this ATF test suite with 20 tests in it, what is the best way to promote this as it isnt in an update set.
09-29-2025 07:26 AM
I needed to promote to prod as we was cloning back from prod to dev so we would lose them.
09-10-2025 06:50 AM
You can’t directly promote an existing ATF suite if it wasn’t in an update set.
Suggestion is below.
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0825608
https://www.servicenow.com/community/itsm-forum/how-to-move-atf-test-cases-from-one-instance-to-anot...
09-11-2025 01:46 AM
Hi @joshmorris
You cannot add test suite directly.
What you need to do is, add all the child tests to update set first then can you see the option of adding the test suite to update set.
Shaql
