Pull field values of form to display in UI pages
gkris
Have created a UI action (Preview button), when clicked, an UI page will pop up as preview. All this is happening before I submit the submit button.
My requirement is I need to pull certain filed values to display it in UI pages. However, I am unable to pull the field values to be displayed in UI pages.
What should be my approach for this requirement.
Hi Göran,
Thanks for the link. Will have look into it.
However, I got the required result using scripting in HTML column of the UI page.
Gagan k
Hi Gagan,
Any update on this?
Can you mark answer as correct, helpful and hit like if you were able to achieve the requirement. This helps in removing this question from unanswered list and helps users to learn from your thread. Thanks in advance.
