Record producer fields mapping
DSV22
Hi team,
I have 3 fields in record producer to map with the 3 fields with incident form which I have done.using the script
current.business_service = producer.field_name;
current.category= producer.field_name;
Category field is taking the backend choice value and the Business services field is not taking any value since it is a reference field in the incident form
Can anyone please suggest how to achieve this task to populate the exact values which is selected while submitting the form.
11 REPLIES 11
HI @Danish Bhairag2
I tried with the above script but still the value is not populating
Hi @DSV22 ,
I Encountered the Issue Before , The Mistake was Added a Extra space for the Backend Value of the Choice , please check the Backend Values and any extra spaces
 Or else , try with , In the Variable there is Field Called Map to Field  , tick the Check box and a new Field is Visible , Add the Fields there , if there is a Reference field , check the reference specification tab in the variable and try again  ,
thanks regards ,
Badrinarayan
