11-07-2018 01:08 AM
Hi community,
I'm on a lost concerning how to populate a reference field on a record producer.
I've searched in the communities and found many posts concerning this and tried to follow some of them but nothing seems to work.
Situation:
I've got a record producer that will create an incident.
On this record producer I have 2 variables, both are reference fields, that are 'map to field'.
The first variable:
Question: Requested by
Field: Requested by
Label on incident form: u_requested_by
Reference: sys_user
Default value: javascript:gs.getUserID();
This field is made invisible via an UI Policy since this will always be the current user.
Second variable:
Question: Registered for
Field: Caller
Label on incident form: caller_id
Reference: sys_user
What I'm trying to achieve is that 'requested for' is populated with users of the same company as the user in 'requested by'.
I've learned that I need to use a script include for this and with some examples tried to create a script (I'm a complete scripting Newby) but cannot get it to work.
I've also learned that I should call on that script in the advanced reference qualifier of Registered for.
I've tried something like: javascript:new getCompanyCurrentRequestedBy() and also javascript:new getCompanyCurrentRequestedBy().getCompany() but both do not work.
The script include I've created:
var getCompanyCurrentRequestedBy = Class.create();
getCompanyCurrentRequestedBy.prototype = {
initialize: function() {
CompanyCurrentRequestedBy: function getCompanyCurrentRequestedBy(){
var usrsList = ' ';
var cmpny = current.variables.u_requested_by;
var usr = new GlideRecord('sys_user');
usr.addQuery('company',cmpny);
usr.query();
while(usr.next()) {
if (usrsList.length > 0) {
//build a comma separated string of groups if there is more than one
usrsList += (',' + usr.sys_id);
else {
usrsList = usr.sys_id;
// return a list of sys_user id's for the selected company
return 'sys_idIN' + usrsList;
type: 'getCompanyCurrentRequestedBy'
Can somebody please help me to achieve the goal of populating 'requested for' with only users of the same company as the user in 'requested by'?
11-08-2018 04:20 AM
Thank you guys for the replies. Because of some system difficulties I could not reply or update yesterday but I did manage to solve the issue.
On the reference field I placed the advanced qualifier: javascript: new getCompanyCurrentRequestedBy().getUserList();
The script include I've used:
getUserList: function () {
var grUser = new GlideRecord('sys_user');
grUser.get(gs.getUserID());
var company = grUser.getValue('company');
var query = '';
query += 'active=true';
query += '^company=' + company;
query += '^EQ';
return query;
11-07-2018 01:54 AM
Add this to reference qualifier and see if it works
javascript:'active=true^company='+current.variables.u_requested_by.company
If you want to also exclude the user who was selected in requested by
javascript:'active=true^sys_id!='+current.variables.u_requested_by+'^company='+current.variables.u_requested_by.company
11-07-2018 02:34 AM
Hi Bart,
imkalai beat me to it, in this case you can do it without a script include.
If you do have cause to use a script include in the future as a reference qualifier you would have to change what you have to:
javascript: new getCompanyCurrentRequestedBy().CompanyCurrentRequestedBy(queryValue); and pass in the value you want to query on. (new ScriptIncludeName().functionName(value)).
For example:
Reference qualifier:
javascript: new userUtils().getCompanyQuery(current.variables.caller_id);
Script Include:
var userUtils = Class.create();
userUtils.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getCompanyQuery: function(user) {
var userRec = new GlideRecord('sys_user');
userRec.get(user); // get record for sys_id of user passed in
return 'company=' + userRec.getValue('company');
type: 'userUtils'
Hopefully the above example helps you out in future when you have a use case for using a script include as a reference qualifier. If you want me to explain any of the above, please don't hesitate to ask.
11-08-2018 04:20 AM
var query = '';
query += '^EQ';
return query;
