Record Producer variable field length
dgrayson
Kilo Explorer
I am using several record producers and mapping the shor description field to the short description on the incident and enhancement forms. However, the maxium character limit on the record producer is higher than the character limit for the short description filed on the forms that the data is being sent to. This is causing the data being entered on the record producer to truncate on the forms. Is there a way to shorten the field length on the record producer variable?
Debra
Hi Debra, may I know how you've implemented this? I couldn't seem to find this attribute within the form. Appreciate your response. Thanks
