‎09-06-2022 12:55 AM
We have a requirement for making a list collector field (server) to show choices based on the values of variables selected previously (environment, operating system and application). We have a table including these 4 fields. There is a field in the table (Type) to differentiate the data from Application or Server.
What we need is a reference qualifier on the server variable to populate choices with :
1. Type is Server, filter the choices based on the selected application, environment and operating system variables.
My script: javascript:'current.variables.server='+'^u_type='server+'^u_environment='current.variables.environment+'^u_operating_system='current.variables.operating_system+'^u_application='current.variables.application;
Thanks.
Request Management
Service Catalog
‎09-06-2022 02:34 AM
Hi
please try this
javascript:"u_type=server^u_environment="+current.variables.environment+"^u_operating_system="+current.variables.operating_system+"^u_application="+current.variables.application;
Also ensure in the variable attributes of the list collector you add this
ref_qual_elements=environment;operating_system;application
‎09-06-2022 02:41 AM
Hi Ankur,
Thanks it helped.
‎09-06-2022 02:50 AM
Hi
Can this be used in a Multi Row variable set?
Considering the environment, operating system are independent and Application, Server are in MRVS. if no, How can we achieve this?
‎09-06-2022 03:04 AM
there are some restrictions when you wish to add advanced ref qualifier on MRVS variable based on outside variables
but here is a workaround
regards
