‎05-08-2022 10:45 PM
I have a variable the type is look up select box.Out of all records i need to seggregate only active records.How to acheive this by using reference qualifier?
‎05-08-2022 10:54 PM
Hello Shaik,
Please see the below variable of Lookup select box type, You can just mention 'active=true' as per below screenshot in reference qualifier.
Please Mark ✅ Correct/helpful, if applicable, Thanks!!
Sulabh Garg
‎05-08-2022 10:55 PM
‎05-08-2022 11:01 PM
Hi Shaikh,
In Reference qualifier field type javascript:'active=true'
‎05-08-2022 11:10 PM
Hi @Shaik
You can add the reference qualifier directly like:
active=true
Please mark my answer as correct if this solves your issues!
If it helped you in any way then please mark helpful!
Thanks and regards,
Kartik
‎05-08-2022 11:21 PM
