Reference qualifier with catalog item
Priya75
I have a variable. name "ABC" it's a choice list, and another variable which is a List collector name "BCD". So variable BCD depends on ABC variable.
So I have used a reference qualifier in BCD variable.
javascript   new ScriptIncludeName.FunctionName(current.variables.u_bcd);
The script include is client callable and when i checked it is coming as empty. any idea how can get desired values..
12 REPLIES 12
variable name is correct.
Are you getting anything in the log on script include?
-Anurag
yes , i am getting the value text. but the value is empty.
Also the choice's are coming from the table, is that could be a problem?
the choice of variable ABC is coming from the table, when I checked onChange client script on ABC it is giving me the correct choice. but that value is not getting passed to script include.
Hi @Priya75 I see the issue now, the below line is incorrect
ga.addQuery("value", value); // there is no value field in incident.
change this to
ga.addQuery("state", value); // now you can compare state with value
Harish
I have just given the example, as i can't share the proper details.
