Refreshing an iFrame from a client script??? or anywhere???
theiser
First of all, I am doing this in order to create a filter on the service catalog.
I am looking for code that will refresh specific/all iFrames. Here is the problem.I have an iFrame on the left that contains a specific view of the user profile. I have been able to add a client script that will automatically save/update the profile if a box is checked.   I then have a BR that adds that user to the group that was checked. I now need code that will update the iFrame on the right side.
Refresh iFrame.tiff
Brad Tilton
It sounds like you're inside of one iframe and trying to change the src on a different iframe. In this case when you call document, it's limited to the elements in your left iframe. In order to get around this, you should be able to use top to start at the top level document.
Try:
top.document.getElementById('gsft_main_az').src = top.document.getElementById('gsft_main_az').src
You could also do something like this:
top.document.getElementById('gsft_main_az').contentWindow.location.reload(true);
11 REPLIES 11
Finally got the answer using CustomEvent.fire('frame.resized'); this will increase the size of the iframe by user interaction on the form. Cheers all.
Hi Saurabh,
Please share the details on how you have achieved resizing of iFrame.
Thank You,
Narmi
